- Seattle, Washington
I already removed the trumpets from the air box but did not get around to installing a wet pipe this winter, will it be ok to run it that way this summer with the trumpets removed and a stock pipe? Thanks!!!
should not have to, does not make that big of a change.
It did on the 750s. I removed the trumpets and then my ski 'stumbled/hesitated' in the mid-range. I had a choice of either rejetting or putting the trumpets back in. Since I destroyed the trumpets removing them, I ended up just partially blocking off the holes the trumpets were in with duct tape to get my ski to run right again. This was with a stock pipe.
I think I read about the trumpet trick on the Group K website.
750's and 800's different animal.
