- Netherlands
Hi All,
After doing some online research on this forum, I recently bought my first Jetski. A Trixstar freestyle ski with a lot of upgrades (according to the previous owner).
Now I'm really interested in the items that are used in my ski. Also for maintenance it's very helpfull to understand my own ski.
Hopefully you can recognize the parts of this build.
The information I have about my ski.
Items I'm sure about:
-Trixstar Full Carbon Hull
-Aluminium pole with carbon chinpads
-Carbon exhaust + waterbox
-Yamaha 62T crankcase (62T00 Y-1 casted on the case with next to it a circkle with OU18 casted)
-RRP Trim system
-5 or 6mm spacer below cylinders (hard to measure but I think it is 6mm)
-Mikuni corp double carburator, but size unknown
-MSD ignition spark plug caps (not sure what type of ignition is mounted)
Items told by previous owner:
-6mm stroker
-~1000cc engine (bigbore+6mmstroker) so when bore is 92mm there is 984cc? (according to this tread?)
https://www.x-h2o.com/threads/yamaha-62t-61x-displacement-vs-bore-stroke-combinations.5136/ ?
On both crankcase and head there is written ''ml''. I already did a research, but cannot find any cyl head looking like mine.
Also the cylinder cases are not the standard 61x or 64x castings. but cannot find cylinders which have the same look.
Is there a way i can check the CC of this engine quickly?
What kind of head gasket is used on this kind of cylinder/head combinations?
Do you know whats the brand/name/type of the cylinders and cyl head?
Many thanks!
-RRP Trim system
-6mm stroker
Many thanks!
