Ski triple 1100cc swapped Kawasaki 650sx
Selling my custom triple 1100cc swapped Kawasaki 650sx!
It has a lot done to it,
the hull was shortened 6 inches, the hood was shaved along with part of the hall to match the hood.
Tray was widened with custom fiberglass foot holds,
The front of the ski was rounded, reinforced and the pole mount was moved forward.
It has a custom made pole and a pressure tested aluminum gas tank
The 1100cc triple was freshly rebuilt only five hours on it. It has new crank, pistons And rings, and the cylinders were
re -sleeved
also has a cold fusion cylinder head,
custom pipe, and electric fuel pump.
It has dual 800 GPH bilge pumps, also has about 30° of trim with a RRP trim cable skat Trak 8/16 prop
Blowson freestyle Cone
WORX Intake Grate
The ski runs great, its maneuverable
Super stable, and has A crazy amount of power!
The ski has lots of money put into it and hundreds of hours building it, sad to let it go, asking $7800.
i have a question about the pole did you use the stock steering cable thinking about doing it to mine. also do you still fill at the factory location?
It was a complete custom-made pole/bracket. the mounting location was moved up like 8 inches or so. I was able to use the stock steering cable.
But I was also using part of the stock steering system for it, (like the swivel part)1C4244E8-12FF-4230-95A6-337DE27BC9A7.jpegD2163641-E51F-44D9-BA79-212D45E97239.jpeg756B0024-7EC3-450B-AE0C-922A321DB4DE.jpeg45DD0BB1-2D32-4F21-B21B-19C497B6EC55.jpeg69624C16-DE40-42C7-819C-EA961F073BEC.jpeg2544EF0B-7C5A-4C34-B470-F0AFE4FBEF00.jpegF5A584E7-8C2C-4939-9CE1-87441A26F613.jpegA7FA0863-B94F-4502-B116-863DDDF43076.jpeg
Okay awesome I think I am going to do it. My pole almost looks like what you have mine is -2 from stock did you use the stock length or was it shortened?
It was completely (custom-made) from tubes and flat sheet of aluminum.
I don’t remember the dimensions that I made it to. The only thing I use from the stock pole was the (turn plate).
I don’t know if you saw in the pictures,
but I reinforced that lower section that I mounted the pole too. I would recommend doing that. It’s too thin down there to mount a pole stock.
yes i seen in the pictures, looks like a winter project
That hood and nose shape looks really similar to my fixies hood and nose.
Now you got me thinking and that's a bad ,bad thing.
looks like I got this ski through a buddy who owned it. Was sunk and recovered somewhere in AZ last year. Just brought it back to life with a low hour 900 swap. I have a ton of questions about this build! It has been so hard to put this puzzle back together! So glad I found this post
