Trinity Composites
Lightweight Evolution
- Palm Bay, FL
The Evo ES is our new baseline hull. The layup schedule is done and ready for abuse. The hull build consists of E-glass with s-glass reinforcements strategically placed. The hull is a lower cost with the same attention to detail and process control as the Evo XF and PRO. The EVO ES completes the Evo line of hulls that I have been waiting to offer. The ES is our baseline product, which in comparison to other after market companies is a high end hull for the price. The build starts with epoxy primer opposed to gel coat. Then a engineered blend of e-glass and s-glass is laminated involving a pre-inpregnated process using premium vinyl ester resin. Which the process is not new, and is used in the XF just never talked about until now. This process keeps weight down and strength up, as resin rich layups are inherently brittle. Every hull build that is offered has a detailed documented layup schedule, ensuring consistency to within 3lbs of each hull in its line. Also to control placement of laminate stacking. These hulls are the real deal.
Hull consists of: s-glass/e-glass, vinyl ester resin @ 100lbs. Hull options: full length or -2". Includes: pump shoe, dual cooling. trim tube, scupper, exhuast, all hardware needed to swap stock kawi equipment, nose piece, ride plate, footholds and a carbon/kevlar hood.
Price is $5299.99 This is being offered on the forms first, then updated to the web site soon.
