Trim Tilt Freestyle?
Big Kahuna
Administrator
Tuscaloosa, AL
I know dan is nosing in bf and hes running a 62t with a mild port job and a single full spec carb with a msd enhancer
and that is as far as he will get............. why? Not enough power..........
if you go back 2-3 years, you will see Lenzi trying them at the WF and he was not making them, why? He did not have the power then, motor displacement rules back then was still at 800cc's.
onlyFX-1
Jace Forest...BRAP!
Im sorry but it hard for me to beleave that he wont get any further than nosing them in. I know he will be pulling them once he switches to total loss but im sure he would get them without it would just take time
P
PancakePete
Guest
Not doubting Dan... good rider..
But I would put money that he is not flat to flat Backy
with that setup.. :popcorn:
X2 Once Dan puts the total loss on I think he will be getting them all the way around.:brap: A ported 701 with total loss on a true lightweight boat should be suifficient for backys. IMO ...... Dan needs to ditch the stock waterbox for a x-metal... that will take off some more weight out of the nose.
Its all about off idle hit.... and thats what total loss gives you!
jeepmark4x4
Backflip, weeee
Marietta, GA.
Or no waterbox :sneaky: for a really light nose
onlyFX-1
Jace Forest...BRAP!
If someone is getting this far around, its not too hard to beleave they could go plate to plate with a little more mods like TL
exactly... let the haters hate! Are they doing flatwater backys? :swordfight:
Total loss is all Dan will need..... Some porting wouldnt hurt either... I think he told me right now all he has Is cleaned exhaust ports :bigeyes:
It couldnt have something to do with his talent...... must just be that 60lb hull thats missing 90% of the bondrail from doing double BR's in the SUrf :haha: :biggrin:
Someone else can bring out another batch of popcorn.
:haha:
parrdaddy
No he will not!
:haha:
What? You don't think anyone on a 60lbs hull could pull of a backy? Duh, it's cake! No talent required.........just pull the throttle and lean back right :headbang:
P
PancakePete
Guest
:haha:
Believe it when I see it... Like peeps say to me.
No offense to anyone, But I have had 20 - 1 3/4 double barrels, but that not a double.
So alot of people get credit for 1/75... Than I can say it too.. but technically its not 2 until its 2. Werd !
No !:poke:
sjetrider
honestly to pull a flat water back flip you will need the following.
1. A very large engine, well over 800cc just go ahead and figure on about $4000.00-5500.00 for the motor alone.........
2. 49mm dual full spectrum carbs and manifold $2500.00
3. Lightweight hull $5000.00-10000.00
3. MSD Total Loss Ignition $1000.00 +
4. A real trim system $500.00
Figure $13,000.00 and that does not include the nuts and bolts...... or foothold, turf, handlepole, steering setup, pump and many other components.
You forgot BIG DAYUM NUTS PRICELESS
