Looks like a good reliable surf setup:biggthumpup:How about this? I gotta give props to crammit442 for making this for me. I'm using a single channel setup and decided to use the OEM coil instead of MSD's. I also have the Jet Ski Solutions terminals on it. So far, it appears to be running fine, but I only have an hour or two on it. The solenoid, coil and switches are inside the OEM ebox.
Yep a must or you really don't know what you are running. Good idea even with a non-TL system especially if using an aftermarket Flywheel.On top of that - when I refered to timing, I mean actual timing, verified with independed timing light. :biggthumpup:
