Other the Slap-deck project
hhh
well this is probably the lamest build thread going right now, but im hoping you guys will keep me motivated.
i havent had a fully operational ski since 2009. lot of life changes and some injuries have kept me from being
on the water, but summer is here and i cant take it anymore. so i just decided to use the parts i have laying around
and build something i can ride and have fun on. im rebuilding my old sn for i think the 3rd or maybe 4th time now, its like
a bad ex gf that just wont go away so i decided to just embrace it.
hull is already in good enough shape, but i had to make more room to mount my x-jet pole bracket. this thing is huge!
i got it all trimmed out last night and some foam poured, hope to shape it this afternoon and maybe lay the glass down this weekend
if i can find the time.
as for the powerplant your all going to be jealous haha bone stock 650 out of a 91 wr3. i picked this up last spring for almost nothing
and thought it would be a good girl friend boat till last weekend the drive line stripped and i dont feel like fixing that thing at all so engine
and what ever else i can use is coming out.
IMG_1320.jpgIMG_1334.jpgIMG_1335.jpgIMG_1336.jpgIMG_1337.jpgIMG_1338.jpgIMG_1339.jpgIMG_1343.jpg
hhh
30 mins to an hour a night and she'll be good to go.
dig the square love, even if it's only out of convenience.
its not just convenience i love the sn and always will.
but my other hull needs tons of hours and a lot of money spent on it to make it
a good hull. i had always planned to put this one back on the water for the woman if
nothing else, but the x-jet is still in pieces and i just want to ride!
Waternut
Customizing addict
Macon, GA
I always liked the flatdeck when I was riding it. I liked it even more because I could ride barefooted without tearing up my feet. It was just really inconvenient to remount it and I gave in and went back to normal.
hhh
it is a fun ski to ride, i always side mounted under power and never had trouble, it was a lot easier on the flatdeck. just pin the gas and pull legs up and it would spin right under me.
hhh
Made a little progress this morning
hhh
Almost ready for glass once this sets and gets sanded.
hhh
Still ugly, but almost done
hhh
Got a few hours off from work this weekend and finished the nose and got the pole all mounted up and cables ran.
I need some pole bushings for this old xft pole the ones in it don't look like any others I've seen. Anyone know what will work or do I have to make some?
hhh
IMG_1868[1].jpgIMG_1869[1].jpgIMG_1870[1].jpgIMG_1871[1].jpgIMG_1872[1].jpgIMG_1873[1].jpgIMG_1874[1].jpg this might have been the longest build for a crappy ski, but its pretty well done. took it for a water test last weekend and i have a leaking gas tank seal and i think i need to clean the carb basket again. other then that it was good. oh and i need a pole now before i can get it back out. Stock RN pole please!!
hhh
ive been polled!
carb rebuild happening tonight.
and an fyi i am running a tdr resonator with water injected to it. its not annoying loud once on the water. when its dry its brutal though. about the same as a atp or powerfactor box when wet and only 85$ new and he will make the inlet and outlet any diameter you need.
Hows that exhaust set up work for you on a 650? Is it just a 650sx pipe with a/m manifold or are there other mods? I have one SN do to lack of funds will be useing a 650.
hhh
that TDR resonator is awesome!! only 85 bucks hmmmmmmm how loud is it when it drys out? cause i am about to spend 80 on a used rn waterbox and this seems like a better way to go.
For 80 on a rn box I'd buy that. It works and it's really light, but without water it's just a straight pipe and loud. I also have rear only exhaust. and that helps when on the water to.
https://www.bansheedepot.com/proddetail.asp?prod=02-0087
hhh
Only part changed is the rear lower inlet was welded closed and the nipple added to the stinger.
I know this setup works, but my carb was in need of rebuilding and acting funny when I went Sunday so can't say anything about performance gain yet. I did use this engine completely stock before the pipe change. only other mod is a 61x cdi for the higher rev limit.
I should feel a noticeable difference
And get a better idea of the cheater pipe gain on a stock 650.
