How come you don't just ask me? I can probe my 750 cases and get you an exact depth. Put up a picture when you get the flywheel off. I want to see the stator mounting flanges.Does anyone here know how much I need/can tap the cases? Since I fried my 750 electronics (just the ground wire thankfully and not the stator as well:cheer: ). So who's done this and remembers how much you tapped the cases. . .
Don't think so, I measure 5/8" max on the top hole, and 3/4" should be good on the bottom as there is more meat in the casting. The top one is where you must be carefull not to penetrate into the crank area. Someone back me up here.did you get the info you need?
