So here's an update. Today I replaced the head gasket. There was quite a bit of debris in the channels around the cylinders where the cooling water circulates. Clean it all out using an air compressor. Put the ski in the water and if fired right up but still it would not piss out the side....
So next I got the water hose and started flushing every single line in cooling system. When I got the cooling line that shoots off the pump I could hear water spraying UNDER the tray where I cannot get to it.
I noticed this line enters the hull on the right side of the ski but then enters then engine compartment on the left. WTF? So somewhere under the tray this line traditions for right to left. I'm guessing there is a break there and that's why water is spraying down there and not ever making it from the pump to inside the engine compartment.
Any ideas?
Thanks.
Any ideas?
Thanks.
