- Miami, FL
Well the pipe is getting way too hot. And I'm scared I am damaging the motor with all the test runs and it getting too hot.
Did you check the pump fitting, did it get swapped out. I forgot to to swap it on mine and guess what, it runs hot.Ski is still over heating and can't figure it out !! Driving me crazy.
I'd take the jet out. check my head pipe with a garden hose make sure it is flowing. close your middle and bottom screws. open your top screw two complete turns, that's completely open. I run a wet pipe, tbm flywheel, skat 13/18 tbm stuffer, tbm intake grate, prok filters and timing advance jumper. I did drill/tap the pump so it's 3/8 pipe and 1/2 hose. that's on the wife's sxr.
Only jet I run on hers is the one that came on the chamber from factorypipe.
It has single cooling line only
