- Clearwater, FL
I'm pretty sure my ADA head for my SJ said 23 lbs on the girdle studs but Chuckies probably right
Yeah thats what my instructions said for my ADA Head that I just installed on my SJ. So far so good.:dunno:
Dan, 23 ft-lbs is not enough on the (6)10mm girdled studs! If you start to make any big horsepower yours WILL come loose too! I USE no less that 36 ft-lbs up to 40 ft-lbs for all out competition motors (high compression).
P.S. I've used Marv's (ADA/ Brooks is his son) heads for about 12 years, and I have been through it all with them on their stud breaking and coming loose problems. On my early ADA headed race motors I had to spotface mill about 3/8 in off my ada heads so I could run ARP grade8 hardened block studs (they would rust, but so what when you needed to win races) for a Toyota motor to keep my race 5mm strokers in my blasters together.
