I need some help! The other week out in the surf I busted three engine mounts and the motor shifted right forward, When I went to replace the engine mounts there were shims everywhere. I wasn't sure of the correct way they went back in so I didn't use them. Now I have a horrible vibration problem!!! I have heard that you need to align the motor and pump??? How do you do this?? Should I put the shims back in, what is the correct way because some are different thicknesses to others. Or have I bent a shaft or something??? Any help would be awesome!!!
