superjet issues
monkeyboy650
superjet
i have a 61x with a type 4 and a pro tec cdi. it runs like ********. didnt want to go at all and barley got up on plane. and now has no spark. the spart comes and goes every min or so. i need help. already changed the coil.
DAG
Charlotte, NC
test your plug wires
cutting them back from the plug boot typically solves the problem
might also have a bad cdi, or a loose ground wire
DAG
Charlotte, NC
not the s/s,
maybe on the cdi and a maybe on stator.
I would first test your plug wires, (its quick and easy) check for continuity with a meter by wiggling them every inch or so and see if theirs a break in the wires..
i'm no electrical expert
tom21
havin fun
clearwater FL
had ski in the other day and the ground was solid feeling, but when the ski ran for a few it would lose power to the cdi.
also had a ski in that lost power some days and others was fine for a while. turned out the black ground wire on the inside of the stator was corroded. electrical stuff is just silly sometimes. you need to track down where you lose power. checked all this crap in like 5 minutes after removing and opening the ebox with just a test light.:thinkerg:
