Hi, today i took my ski out after about a month of sitting. When i was riding it I noticed that the engine was bogging down if I tried to gun the throttle and I needed to gradually increase the gas to keep the engine from bogging down. I rode the ski for 20-25 minutes then I noticed that it started to the create white smoke from under the hood. I could see the smoke escape through the stock hood hand holds. I immediately beached the ski and I noticed the engine was very hot, more than usual. This is strange as I saw water was flowing through the cooling system and exiting through the opening on the side of the ski as usual.
Any ideas about what could have caused this? Unmixed or not properly mixed fuel? I havent modified the 701 cc engine since the last time I used it and it ran fine then. The 701cc engine is stock except the factory b pipe exhaust system
Thank you
Thank you
