superjet engine overheat and smoke
Kuwait
Hi, today i took my ski out after about a month of sitting. When i was riding it I noticed that the engine was bogging down if I tried to gun the throttle and I needed to gradually increase the gas to keep the engine from bogging down. I rode the ski for 20-25 minutes then I noticed that it started to the create white smoke from under the hood. I could see the smoke escape through the stock hood hand holds. I immediately beached the ski and I noticed the engine was very hot, more than usual. This is strange as I saw water was flowing through the cooling system and exiting through the opening on the side of the ski as usual.
Any ideas about what could have caused this? Unmixed or not properly mixed fuel? I havent modified the 701 cc engine since the last time I used it and it ran fine then. The 701cc engine is stock except the factory b pipe exhaust system
Thank you
Blue
Judging your cheapness
St Cloud Florida
Sounds like u have an exhaust leak. Put it on the hose and crank it without the hood to find the leak. An engine cannot run on the air and smoke inside the hull thats why it was bogging.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Kuwait
Thank you very much. The smoke was generating in the left part of the engine bay. Looks like I have to take it to the repair shop to fix the leak.
Just check ur couplers man . I wouldn't take it to a shop for that,do as the above guy posted hose on a stand find leak replace or tighten where it's leaking
Kuwait
I found the area of the leak and Ill check if it needs replacing or not
