Super Jet Superjet engine mounts question
Spain
I have just been out on my superjet and broken 3 engine mounts.
Does anyone know if they are generic mounts used across all yamahas or jetskis?
I am currently away with it and wanted to take this to a boat shop to fix quickly so i can use it again out here in spain.
Thanks
They are not generic mounts....you need either new stock mounts or aftermarket mounts......however. If you want to do a fix which actually lasts for years...I know this. I have done it many times.....go buy some stainless steel counter sink self tapping screws ....drill 4 holes from. The top of the mount and another 4 holes from the bottom of the mount..these lower holes at 45 % rotated......through the aluminum only....drill counter sink recess in the aluminum...then screw in the stainless screws which are short enough not to go into the lower aluminum section, but long enough to overlap the screws from the other side.....its really much easier than it sounds.....works so well you will forget about them for years to come....problem solved
JetManiac
Stoked
orlando
Thanks
They are unique mounts just the SuperJet model.
