dirkdiggler
- WI
I went to test me 1991 Superjet compression today and it seemed to have a problem!!
The ski has good start/stop switch
New battery
When I hit the start button the motor does not turn over but I do hear a little "pop" noise in the electrical box when ever the button is pressed. Then after about 5 presses of the start button and 5 "pop" noises later the ski starts turning over like normal. Then I check the other cylinders compression and I get the "pop" noise everyother press of the Start button.
When the ski does turn over I do NOT hear any bad/unusal noises from the starter.
Any Ideas????? Bad ground, starter dieing etc......???
New battery
