Superjet 1200
Skywalkers Envy is 360 lbs and he flat water backflips it. Adding 46 Lbs to a Stock SJ puts it about the same weight.
What mid shaft did you use? The gpr ones are shorter than Sj and would allow you to move the motor back some.
Aaron
few really fun mods for this ski would be raise the comp (I am running 175psi on my 65u) and a riva rev box. Also what jetting specs did you end up going with?
