jetskiking
Im done sanding!!!
- Dallas Georgia
O.K. I know this is info Ive seen a thousand times but now that I need it I cant find it
. I need instructions on how to turf the footholds with footprints. Ive got the padding and and turf. do I lay a layer a of padding all the way into the holds then cut a piece that contours the shape of the print and turf? Do I cut the footprint out of the sides of the padding? This would not leave any padding in the footholds but allow for more room. Or should I run one layer into the holds and then run a second layer with the prints cut out? This would have two layers of padding in the tray but one in the holds. Maybe Ive seen it done all three ways? Which works the best? Which looks the best? Any links to threads would be good.
