- Tuscaloosa, AL
Check with Art at Jetworks, he has a nice stroked setup that I dont not think runs much more than your budget.
I'm confused to how 83mm would hit harder then a 85mm if there both stroked.... I realize it's becuase of transfer ports but it just don't make sense. The first motor I'm looking At looks real good and people have said it makes good power...
either of those motors you listed would be good for less than 2k,I have 2 diff 5 mill motors,one is 82 mill round top the other is a 85 mill flat top and it stomps all over the smaller 82. the 82 is runnin tl with more timing as well ported by someone at greater while tj was there. The 85 was ported by lamey and runs a enhancer.transfer volume is less but she kills.
id try and ge the transfer and exh duration #s on both those motors and choose with at least that info
I wondered how long that would take.
Didn't Gary use to do Wammers port work also?
Buddy of mine had a 61x Bigbore that Gary ported. Good motor setup.
TJ never worked for Greater. He went straight from Riva to his own deal. Yours was probably done by Gary Pominowski. He was in charge of Greater's motor department.
SM
how come the ski clinic isnt building your motor?So recently i blew up my 701 real bad. took out everything but the head. so im looking to built up a motor. im wondering about stroker cranks tho. ive been thinkin about a 4 or 5 mm stroker with 83mm ported 61x cylinder. Would something like this work?
would it be better to run big bore? itll be stricky flatwater. who should i contact about strokers?
thanks
thanks
If you are talking about the one you got from Dee, that motor was built by Gary Lamb. He used to work under the Riva/Team Yamaha Support Team.
Scottie
The Ski Clinic would be building my motor but I have nothing to start from... destroyed everything, so actually decided to go with a complete motor setuphow come the ski clinic isnt building your motor?
Have not heard that name in years!
