Stock Squarenose to Sweet Superjet --- step by step my first ski
2lick
Brap!!!
Limerick, PA
I dont know??? I tried to be original this is the design I had it in my head for a while... Sorry if it looks like someone elses!!! Can I see a picture of "freestylegeeks"
Its not metal flake, just a shimmer
THANKS!!!!!!!!
2lick
Brap!!!
Limerick, PA
Cool thanks guy...
I have seen that ski befor on superjett.com OPPS!!!
Well there diffrenet enough.
Im thinking white and black graphics and maybe some yellow on the white to bring out the sparkle.
Thanks-NICK
F
Freestyleriverrat
Guest
Looks good. Nice sparkle to the paint. I need to get on the ball on geting mine done, but I need to wait until the weather warms up.
Y
yamaslut
Guest
Nick.... that ski looks great... lots of great info and awesome write up too... Keep the pics comming bro!!!!!!!!!!!!!
:cheer: :cheer: :cheer:
2lick
Brap!!!
Limerick, PA
Handle Pole:
Wanted to post this real quik. I got my handle pole back from the powdercoaters. It was 130 buck to have the pole and mounting braket sandblaster and done up in glossy black. They did a really nice job:biggrin: , it was just really exspensive IMO.
Just think I might hate it and want it choped short, then I have to paint it again!!!:frown:
I did a step by step of putting the UMI on it but I'll ad that later.
Y
yamaslut
Guest
2lick said:
Handle Pole:
ya ever heard of Krylon???
j/k... looks good
Ohio
Great build thread man!! Thank you very much (and all others who have done this) for taking the time to post it!
beachedflunkey
wavejunkies
Virginia Beach
Did you ever find the time to start jotting down a step-by-step on the paint? I've got a buddy who offered to do mine (primer/omni) but I'd love to know what all is involved... Yours looks very nice :cool2:
2lick
Brap!!!
Limerick, PA
Well not yet, Im writting a damn research paper today but I should have an hour or two do make the paint proccess.
Check back tonite ill try my best!!!
2lick
Brap!!!
Limerick, PA
Lucky you I have another 6 weeks to go....
I stayed at school this weekend to get homework done. If I go home all I do is work on my ski and see my girlfriend.
I miss my ski :-(
2lick
Brap!!!
Limerick, PA
Rail Extentions!!!
Goal:
Extend rails 3/4 inch.
Not pay $100 for a rail extention kit.
Homebrew something better.
Material:
Composite decking spidles
WS 404 filler/glue
Fiberglass Filler (duraglass)
Clamps
Paper towels
Marker
Hand saw
Table saw
Step bt Step:
  • Flip hull on top deck
  • Rip Spindles in Half on Table Saw
  • Sand with 80 grit on spindle side to be glued to hull
  • Sand paint off hulls rails
  • Hold board up to back half of hull
  • Hold other half to front
  • mark where two pieces meet
  • Bend board to shape of hull
  • Do a pre-clamp on (dry fit)
  • Set clamps up for fast use
  • Mix resin and hardener
  • Add WS404 untill a thick pasty substance
  • Pour glue on boards
  • Clamp board to ski
  • spread clamps out at first then add clamps in between for tight fit
  • Repeat with upper board but work from back (flat) to front (curved)
  • Add WS404 to fill gap at end of boards
  • Wipe excess glue off!!!
  • Leave cure 12 hrs
  • Remove clamps
  • Repeat other side
  • Take hand saw and cut at angle to feather ends in
  • Use 60 grit disk on grinder to mold to the ski
  • Add filler and keep on molding till satified
  • Sand down bottom of rails so you dont cut yourself ridding
  • Flip ski to top
  • Use filler to smooth top of baord to ski
  • YOUR DONE!!!!
Conclusion:
When your all done they are very strong! Let them cure fully (24 hr) before you test them. You will hve to rought up the rails to put turf on them.
Questions, Comments, Responses!!!!!!
2lick
Brap!!!
Limerick, PA
You know me I like pictures!!!:biggrin:
2lick
Brap!!!
Limerick, PA
And then...:smile:
