How the heck do you remove stator screws that are stuck? I tried and tried with a large screwdriver and all my weight and might. The flywheel area is really clean but I'm exhausted and it still won't budge.
heat always helps, and an impact driver. the worst that will happen is you will break the bolt and have to drill it out..... I will use as much heat as it takes because I HATE drilling
