Super Jet Stator for TBM?
swapmeet
Brotastic
Arlington TX
TBM says their Yami flywheel should be used with a 62t stator.
I have been told by the previous owner of the TBM I have that there is mixed reviews on which stator will work. He also told me that both 61x and 62t will work.
Whats the story?
RMBC Freeride
Vintage
Pueblo, CO
If it was designed to work on a 62t stator (which it is) then THAT IS THE ONLY STATOR YOU WANT TO USE WITH IT.
61x stators are physically smaller than 62t stators - smaller diameter inside the flywheel. So people mistakenly run a 62t flywhweel with a 61x stator... and it works.. sometimes. It has a huge air gap between the magnets and the timing will be off and the windings are different on the coils so the voltage produced will be different, but sure it works when it works... But definitely would not try it with a high-end Billet flywheel. No way.
JetManiac
Stoked
orlando
Exactly.
steve-uk
Manners cost nothing
Barrie - ontario
I think its more accurate to say a 61x stator will fit (physically) in a 62T flywheel...
is it supposed to?
i dont think we need a rocket scientist for this one...
TBMs were all designed for 62T stator
You were asking about the runability of the set up, in relation to its working, and I answered that I did not know if it was X or T, but that the whole set up was running perfect, and set up professionaly and everything worked perfect as it should.
I was told by the dealer that I bought my TBM from, that It would work with either one, which i why i said "works with X and T". But thats my fault, I should have just called up TBM. but I was saying that It did not matter, becuase the set up was a perfect running set up, and did not know if it was X or T. I had the utmost confidence that it was properly set up due to knowing who actually set it all up, so even though i wasnt sure X vs T, i knew that whichever one was correct, was the one that was in there.
and I sent you both an X and a T stator so that you could decide which one you wanted. But told you which was the exact set up in my boat, that was set up and had no running issues.
I sent you the whole exact set up that was running in my boat without issues. Many can back that up that it was running fine, Mark wired all the electronics, thats why you see all the nice colored tubing and connections. and Art installed the stator,and torqued down the flywheel.
And as you can see above, its pretty easy to easily have crossed info, becuase apparently it will run with it, its just not the ideal perfect set up, but again, that doesnt matter, becuase the converstion that was occuring was about how it all worked..
http://www.watercraftwerks.com/p686...harging-Flywheel-Yamaha-701/product_info.html it just says "701" where as all the other types of FW(Jetnetics, RAD etc), all those product information pages specificaly state "61X flywheel" or "62T flywheel". Which is another point as to the confusion. Again, my fault for not calling up TBM to find out, honestly knew it was a professionaly set up system, and since it was being sold complete RTR, It worked perfect in conjuction.Sorry for that information, It was cleared up later in conversation. Next time I will simply call TBM about it, but the actual conversation going on at that time was about if the set up was all working properly, which it was.
BruceSki
Formerly Motoman25
Long Island
Ehhh pretty sure you need a 62t stator. I personally wouldn't run a different one than they suggest on a $600 flywheel. That's for sure.
Big Kahuna
Administrator
Tuscaloosa, AL
Whats the story?
Tim needs to reword his website as far as the Flywheel goes.
But beside that, there has never been a flywheel that works with both stators. You have to have a "T" stator for the TBM. Jetnetics use to produce flywheels for the "X" and the "T's. You specified which stator you were running.
swapmeet
Brotastic
Arlington TX
All the questions and controversy could have been stopped within 7 hours and a e-mail to the mfg. Check the time stamps.
Sent this to Chris, as a fyi in case he sells TBM to another (unsuspecting) customer. ... continues to say that 61X might be right. "Very mixed reviews regarding info on TBM stators."
And my apologies to Mike at Optima for getting drug into this.
