- deland fl
picked up a fixer upper raider that has a full tank of most likely pretty stale gas. the seller didnt know when the ski was run last and couldnt guess how old the fuel was (divorce sale) but based on how corroded the pump was, i would say it hasn't run in a while (at least 6mos-year). unless the husband added fresh gas recently before realizing the motor wouldn't turn over. it doesnt smell as bad as i would have thought.
i'm no tree hugger but i do hate to waste that much gas if it can be saved. has anyone had any luck with the additives that say they can liven up old fuel? or would draining 1/2 the tank and adding fresh do the trick. i'm hesitant to add fresh cause if i cant bring it back to life then i've just wasted even more. figured i'd survey the experts before proceeding.
thanks
thanks
