Ss865/ss900 cylinder kit $2000
Very nice SS865 cylinder (88.5mm bore currently needs bore/hone) clean gasket surfaces, everything is as it should be. Comes with power valve assemblies as pictured.
2 New SS900 Domes from xscream
2 New SS900 90mm Wiseco pistons
2 Used head shells one Black, one Red
A few sets of brand new base gaskets (0.020")
Head hardware, cylinder to case hardware.
I can also sell as complete motor or offer building services to suite any needs.
Sent from my SM-S938U using Tapatalk
It comes with 90mm pistons, It is currently at 88.5mm bore.
at 90mm it would be an 865
Understood, My question was what max possible bore is on these sleeves because I'm curious if the XS865 originally starts as a lower CC and becomes an 865 when maxed out, or if these are un-bored sleeves that start undersized enough for 90mm to be the "first bore", and if so what the max bore is after that. This lot also includes ss900 domes, which I assume would be for 92mm bore (904cc), or would those also work on a 90mm bore? I guess these are probably questions for @tricky1 - Genuinely not trying to post-dump by implying this is a smaller motor than what is being advertised, just trying to learn about the platform as I'm building an Edge that is going to want more than the 701 it's currently slated to receive :rolleyes:
Xscream stopped making the ss865 and the ss900 is what they are calling it now. Xscream says they are only offering the larger pistons for this cylinder now and domes shouldn't change much if any between the two. Your dome will just be cut to accept the larger bores. The previous domes were cut in a way I did not like and ordered the new domes for it.
