- Wasaga Beach
Looking good.... I'm in the same boat trying to get my Blaster ready for the DRR. See ya there.
Spray-9 and a foam sanding block. Wetsand with a degreaser.what did you clean the gas tank with
You and me both! We swapped in a 140 main saturday night before you took off, and its 10 fold better already. Might have to go to a 145, we will see. Im currently wondering if the 120P is a little lean. Headed out to burlington lakeshore sunday to test/tune with the CWA guys.Glad you got it all dialed in.
Was that a 46 SBN? What were you at originally?You and me both! We swapped in a 140 main saturday night before you took off, and its 10 fold better already. Might have to go to a 145, we will see. Im currently wondering if the 120P is a little lean. Headed out to burlington lakeshore sunday to test/tune with the CWA guys.
yep sbn46. We started at a 150m 120p 2.0 n/s 95g spring. That was hesitating pretty bad, so i dropped to a 135 main (stock 61x main) to get a baseline, and it bogged with the high 2.5 out. That night we went to a 140 and at 1.5 out i can feel its close. I ran out of tuning time last weekend so ill spend sunday playing with it.Was that a 46 SBN? What were you at originally?
Yes that sure does. The 135 had mine bogging bad enough i couldnt stand up. bone stock 61x motor run a 135 main 120p i believe.Good to know, my engine porter has me running 135main, 117.5p on 61x/61x with 46 sbn, sounds a bit low IMO but i will find out when i get on the water monday.
Bogging or hesitating? Bogging is rich, hesitation is lean. I will ask again maybe he just gave me stock numbers..Yes that sure does. The 135 had mine bogging bad enough i couldnt stand up. bone stock 61x motor run a 135 main 120p i believe.
