I’m running pretty standard NGK BR8ES plugs. Last time I went to check them, the screw-on part wasn’t there. It came off on both plugs and was stuck up inside the caps. I was able to pull one out with a tweezers, but can’t get the other one out.
I’ve read a few other threads on this and some people recommend using the non-screw type
. When I replace the plug caps, should I start using these solid plugs, or did I just have bad luck with these two? They’re not in stock at my local advance auto parts, but I can order them online if they’re recommended. Why isn’t everybody running the solid type, are there any disadvantages?
Thanks in advance
. When I replace the plug caps, should I start using these solid plugs, or did I just have bad luck with these two? They’re not in stock at my local advance auto parts, but I can order them online if they’re recommended. Why isn’t everybody running the solid type, are there any disadvantages?Thanks in advance
