It was last spring mine went out, they have gone up.i saw them at parker, 47 bucks.know of anyplace cheaper?
\on my FX1 sometimes it would work, sometimes it wouldnt.....id be dead in the water in the middle of the basin in Havasu punching the poop out of the start/stop......than boom it would work out of nowhere.
dam gremlins...... my problem was the start/stop..........
could be you got unlucky with 2 start/stops but i kinda doubt that.....could be a relay......... are your grounds ok???
this happened to me at the end of daytona...a few riders thought i was in trouble but i just couldnt get it to start, then bam after 40 times pushing the button fired right up
If it's only in salt make sure you put dielectric (non-conductive) grease on the top of your plugs under the plug caps. Do not put it on the tip where the connection is. A tiny bit of salt water can get under the plug caps and short all that precious spark to the base of the plug.
I had a slow leak, rode in salt water which leaked in and the salt water splashed around. Someone told me the above info. Rinsed out the the plug caps and plugs with a bottle of water and dryed them out. Ran like a champ after that.
Re-apply the grease every few rides.
