SJ Wider Tray - Update
#ZERO
Beach Bum
Florida - U.S.A.
It's just Hydro-Turf molded diamond on the bottom and flat turf on the sides. I like using flat turf on the sides because you don't have to worry about the diamond pattern matching and it's a bit thicker with more compression. I used 20mm high density black neoprene foam for padding on the bottom and 5mm padding on the top rails and top of the foothold so it holds your feet in real snug.
