SJ Throttle Cable Lengths
oxnard111
Creative RE Purchasing
Her's another solution, but not $27.00 (sorry).. I offer a cable that will work with the diaphrams mounted correctly, has a 6mm thread on the carb end, and has the 10mm threaded throttle end. Many Kawasaki customers have problems with the " stainless" cable guide at the intake manifold breaking, this usually only happens if you make good HP or turn high Rpm. The cable i offer will cure this. http://www.watcon.com/Catalog_Pages/Throttle_Cable.htm
Thanks for looking,
Randy
when you say diaphram mounted correctly, which direction do you mean? Diaphram facing engine, or facing away from engine?
W
wydopen
Guest
1993 Kawi 750SX cable, with aftermarket carb mounted cable bracket and UMI throttle wheel.
MUCH beefier cable, far better quality, for 27 bucks brand-new.
Keep buying SJ cables. :biggthumpup:
ive got three of those...good thing i couldnt sell em..
#ZERO
Beach Bum
Florida - U.S.A.
Is this Kawasaki cable any longer than the sn cable?
If he's mounting the carbs with the fuel pumps facing the hull he might what to use the 10mm Kawasaki fuel pump side bracket.
You can get them at Jet-World for 20 bucks http://www.jet-world.com/partsacc_carbsintake.asp
sjetrider
WPS sells 1 cable for damn near all yami's its long enough and cheaper than oem. If you can get a SN or Raider OEM cable somewhere local they will work with room to spare.
I don't know how long it is exactly. But it's reaching just fine in my single carb, reverse mounting (drum towards bulkhead), but that's with -2 pole and XMW straight bar setup.
Ended up taking a chance and ordered a SquareNose Throttle cable. Hopefully it fits in nicely, if not it's taking a trip to Terry Cable to get lengthened.
Thanks for all your input everyone :).
R.S.
