SJ questions
Ohio
Man where do I start?!? My ski is layin' all over the place!
1.)I have 1 old school 650 stock F/A which bolts to the carb with 4 bolts. My current PROK adapters have 3. How do I convert once I find another stock F/A?
2.)I have a greater Yamaha head running 150PSI with current domes. What do I need to maximize PSI and still run pump gas? (I already emailed Greater, just figured I would post here also)
3.)Yamaslut...what was the automotive self sticking trim you used for your bumper action?
4.)Does twist still exist and if so where? I need Orings and maybe some higher compression domes for my friends ski.
Probably more to come...I just can't think right now.
Thanks all!:headbang:
F
Freestyleriverrat
Guest
I'm confussed.......are you wanting to put the PROK adapter on the stock carb? The are two types of Mikuni's, the round (3 bolts I think) and square body (4 bolts). I don't know if that helps you, but thought I would throw it out there.
Ohio
I want to put the 650 stockers in. My curent Proks adapters are mounted using 3 bolts. The stock 650's bolt on with 4.
It sounds like I need to convert round body to square body then....right?
Ohio
No. Well, yes. I want the stuff Nick (yamaslut) used but I have'nt PM'd him to find out what it was yet or where he bought it.
I think someone said PEPBOYS maybe?
beachedflunkey
wavejunkies
Virginia Beach
beachedflunkey
wavejunkies
Virginia Beach
Grrr they just called back realizing it was 1-1/4". Whatever :grumble:. It'll work. I might use a couple bolts or rivets to protect my investment. They are also charging me tax although I am out of state :ugh2: I'll write it off...
WAB
salty nuts
coastal GA
Forget roundbody carbs. All the carbs we use (38's 44, 48, 46, etc) are squarebody SBN carbs.
The OEM 38's that came with SJ's have 3 mounting holes on top to mount a flame arrester. The 44mm carbs have 4 mounting holes (650's &/or 61x cases). So you either need to get 44mm carbs or just use the OEM dual 38's flame arrester. :smile:
Ohio
Thats exactly what I ended up doing. I found a 96-up OEM F/A. Live and learn:rolleyes:
