Side or rear exhaust on a Blaster?
LBE
Eddie Would Go.
Charlotte, NC
Anyone ever try running side exhaust on a B1? Any advantage to running the exhaust straight out the back? other than keeping the pump clean. Not looking to do tailstands or anything, just rebuilding the B1 and wanted to do something different.
If anyone has done this, could you post pics for ideas please.
Thanks
Any input on the SJ rear side exhaust? work well? Does the water pressure when turning affect power?
butti
lone wolf
F-XTC
i almost put front exaust on mine but i chickened out,i still may do it to my next hull.you should try it and let me know how it works:biggrin:
jetskier79
I'm goin' for two
San Diego, CA
I have been STRONGLY considering installing a front exhaust on a blaster. My next hull just might get one. In the surf on a B1, coming down tail first slightly leaned to one side pretty much means your going to fall over.
The downside to the blaster vs. a standup in my opinion is the fact that on a blaster your are either on it of you're off it. There is no in between like there is on a standup. I think a front exhaust would dramatically help to stay ON the ski.
butti
lone wolf
F-XTC
2nd nature said:
why out the front?
well on my next hull i plan on putting a bulkhead at the front of the pump cavity and pour foam in whole rear of the ski under the rear deck.if keep the stock exaust location i will install a fiberglass exaust tube.or i can put a front exaust on and save myself some work.ill cross that bridge when i come to it
WaveDemon
Not Dead - Notable Member
Hell, Florida
good point on the landing angle. when ever my nose is high in the air and the back end is submerged I'm going down. And you are right, you can't fake a landing on a blaster.
butti
lone wolf
F-XTC
the trick is to stay off the trottle until you get through the first "bob"and the pump fills with water.if you get on the throttle right away the pump just sucks air and cavitates like crazy.i too think that front exaust would help this a little
jetskier79
I'm goin' for two
San Diego, CA
That's definitely the trick. It's not so much the straight up and down landings that cause problems. It's the ones that are straight up and down with the nose tilted off one way or another that cause issues. Then when the ski "bobs", it's bobs off in a sideways motion.
I've gotten pretty damn proficient with landings, but I do think a front exhaust would allow them to be that much better that much more often.
brentR
way fast whitey
Toronto
the ones that look like this?!?! :woot:
LBE
Eddie Would Go.
Charlotte, NC
I usually side board from the left side, so I would run it out the right side. Seems like it would be really simple, easy access.
Thanks for info fellas. Butti: I have been using pics from your B1 build to do my ski, thank you!
So it looks like I will give this a whirl. I'll post pics when I figure out what I'm gonna use.
Is this to help keep the transom from cracking?
butti
lone wolf
F-XTC
i am honored:veryhappy:
you could do it on the cheap with a rod holder:ponder:
butti
lone wolf
F-XTC
yup ....as sturdy as i made mine after a year and a half of abuse and hitting bottom more times than i can count it is starting to develop some cracks.thats the only other thing i can think to do to make it stronger.the transom is already 1/2in thick!
LBE
Eddie Would Go.
Charlotte, NC
HOLY SMOKES!! 1/2 in?? I dunno what mines at, but I have 4 layers of biaxel and a layer of cloth. Do you think I should add more? That transom takes a beating.
Possibly rod holer, I may use the stock type outlet and make a fiberglass flange on the outside to direct it down. I'll post pics when I do it.
most peeps probably dont know this...but there is NOONE on this coast harder on a B1 than butti...
maybe blaster701..........but butti IS the blasterKILLA :smokin:
