Shattered Piston, Cases, Rod
SkiDaddy
Just Havin' Fun!
Orange City, FL
After a good solid 2 tanks of waist to chest waves at Ponce yesterday my ski suddenly died when landing from a medium wave. I'm thinking the battery cable or something as it would click but not turn over.
Here's what I found. :bigeyes::aargh4::aargh4::aargh4::aargh4::aargh4::aargh4::17::17::17: Looks like jetting & lubrication was nominal, ski was running great all day, hitting hard. Looks like the wimpy cast piston just shattered. All bearings look fine, no evidence of water ingestion.
I think with resleeving the excellent porting can be saved. Anybody know if the slight bulging can be addressed?
DAG
Charlotte, NC
odd,
how long have you been running that cylinder/piston combo?
maby the tolerances were to tight, or compression to high, or bad luck and a defected crank
but look on the good side, the other end of teh rod dident go smashing through your case and through your hull o_0
#ZERO
Beach Bum
Florida - U.S.A.
Ouch... it looks like you're getting pretty bad a blowing stuff up too.
My guess would be that the rod broke first and toke out the piston skirt.
Who rebuilt that crank? :scratchchin:
SkiDaddy
Just Havin' Fun!
Orange City, FL
Are you sure that a Hot Rods crank because the lower rod journal looks to be trimmed down?
Maybe it's just from hitting debris inside the case. :thinking:
It was purchased brand new & came in a Hot Rods box...
Are you talking about the same end machining visible on the "good" cylinder?
#ZERO
Beach Bum
Florida - U.S.A.
I just went to check my own hot rods crank and I guess it's normal for them to turn the end of the rods down.
For some reason I always thought that the hot rods were more rounded on the bottom journal.
SkiDaddy
Just Havin' Fun!
Orange City, FL
If you look at the busted rod you can see it snapped clean in tension; looks like the piston shattered, jamming in the cylinder & the crank kept spinning, pulling the rod in half. So I wouldn't think it was a crank failure.
Damage amounts to new cases, crank, pistons, cylinders, and domes. Resleeving the damaged cylinder would take prolly 6 weeks? & cost $$$$$$$$
Anybody have a stock, low hour short block FS?
Y
yamaslut
Guest
ever thought of kayaking?????
