- Long Island
I have assembled a dozen solas 144 and 148 pumps and have never used the oem washer behind the prop. I have always used aftermarket washers. The oem washer with the rubber binds and rubs against the seals, or bottoms out like youre experiencing and locks up the pump.
Also with fresh seals the shaft isnt going to spin fast without resistance. What you're feeling is normal.
Get a few different thickness washers from jetmaniac and reinstall your impeller.
Sent from my SM-N970U using Tapatalk
