casanova992
4U2NV
- Margate, NJ
Good evening gentlemen!
On the back of my SJ where the exhaust comes out, is that bracket attached to the whole exhaust pipe thats in the hull? And could I use 5200 to seal around to keep it water tight? Same question, for the shaft that the steering cable is pulled through? See pics. Also I grinded off my factory bilge pump nipples outside and inside of the hull, then filled them with a fiberglass filler, ok I'll admit it "Bondo":17: . What do you expect from a poor philly boy, I could barely afford a cheesesteak. Thanx fellas
Vincenz:headbang:
Vincenz:headbang:
