- Pinellas, florida
has anyone had issues with sbt head gaskets? specifically for 61x motors? ive put 2 down so far and they both have leaked water out of the side of the head within 5 minutes of riding. im 95% sure i am installing it properly, lap head and bock till flat. use new gasket, torque in two stages while following the correct tightening pattern, one at 11 ft lbs and the second at 22 ft lbs, which is what the yamaha service manual says. i even used avation sealer on the second try to remove any possible way it could leak, i even let i. cure for 2 days. has anyone else had this issue or am i just a poor mechanic? are there specific gasket makers i should avoid?
