New RUBBER Straps, hull hooks, hull mounts- Waterbox, Battery, Misc. Straps
JetManiac
Stoked
Vendor Account
orlando
Rubber Straps
New 10” HD battery, waterbox, or tank strap -other OEM $14.95
New 11” battery, waterbox, or tank strap -other OEM $13.95
New 12” HD battery, waterbox, or tank strap $13.95
New 13" battery, waterbox strap or tank -Yamaha OEM $29. special buy $12.90
SuperJet battery strap $13.90
* Oem clean used, about 14 inches hook to hook unstretched
Shorter battery strap $13.90
* Oem clean used, about 12 inches hook to hook unstretched
SuperJet waterbox strap $13.90
Shorter waterbox strap $13.90
Tank strap $18.90
* Oem yami clean used, approximately 17" unstretched
Good for kart tanks and PFP style pipes.
New OEM Super Jet shorter gas tank strap 39.99 sale 33.89
* Approx 17" hook to hook-battery box side
New OEM Super Jet longer gas tank strap 39.99 sale 33.89
* Approx 24" hook to hook-hull floor to floor mount length
Blaster battery strap with pull tab $19.80
Shorty strap (6-6.5") $14.90
* Oem clean used, about 6.5" inches hook to hook unstretched
New 5.5" OEM strap 12.99
* 5.5" hook to hook, stretches to 7-8", ends are galvanized
Shortest strap 5.5" $12.95
(these have shorter metal ends, and will not work with std strap hooks without modding the hooks)
Strap Hull Hooks
New OEM stainless hull strap hook $11.99 sale 10.49
(The two on left side in photo)
Used OEM stainless hull strap hook $5.25
OEM captured strap mount -clean, used 7.95
(The two on right side in photo)
New OEM waterbox stainless hull hook with rubber bumper $39.99 sale 37.89
UFO Hull Mounts
JM UFO Std. 6mm SS hull mount $4.90/ea or 24.90/6 pack
(base plate 38mm diameter across and includes stainless allen shorty bolt for strap hook mounting)
JM UFO Junior 6mm SS hull mount $4.90ea or 19.90/6 pack
(base plate 23mm diameter across and includes stainless allen shorty bolt for strap hook mounting)
Perfect for gas tank, battery, waterbox, or pipe strap hook mounting to hull. Also can be used for mounting TL plates and eboxes. Epoxy directly to hull. Marine grade 316 stainless steel construction.
index.php
JM UFO Daddy SS hull mount 6./ea or 25./6 pack
(Uses all 8mm oem bolts like motor mount, midshaft, RN rideplate size)
http://www.x-h2o.com/index.php?threads/ufo-hull-mounts-just-landed.158921/#post-1709400
Epoxy for UFO mounting to hull
West G/flex thickened epoxy kit $40. sale 38.49
8oz mixed
* Thickened and Toughened epoxy to absorb stresses of expansion, contraction, shock, and vibration. Excellent adhesion. Great for dissimiliar materials. Shipped in US only
West G/flex thickened epoxy mini kit $14.99
1oz mixed
OCD Solutions
Rentz, GA
Do any of these straps work with the small AGM batteries? I would like to replace mine with ones without knots tied in them if possible.
JetManiac
Stoked
Vendor Account
orlando
hey jetmania, im chasing 2x oem fuel tank straps and a battery strap to suit a deka etx9 battery in oem battery box. if you can get a price and shipping to brisbane QLD australia 4069 if your willing to ship internationally?
Cheers
Guy.
Hey Chris, I dont know whats up with PWCtoday but its not showing my pms. How much for the 94+ bearing housing/midshaft? Also what ride plates do you have any hows much? I appreciate it...If you did get my pms sorry for the repetition
JetManiac
Stoked
Vendor Account
orlando
pms sent
piratelife
Frandsen works
In the hood wood
I need two gas tank straps and two waterbox straps how much shipped to 86442. I also need the filler hose that goes to gas tank. And a stock hood latch...pm me with prices
yamanube
This Is The Way
Staff member
Mandalor
You can take one waterbox strap and hook it to the front tank mount then take another and run it through that one, fold it in half then hook both ends of that one too the back tank mount. A little ghetto but it holds tight and is a cheap alternative to hard to find gas tank straps.
Ducky
Back in the game!
Charlotte, NC
Looking for some shortttt straps for my Xscream modified jaz tank. Would these "shorty" straps work?
