Rubber Straps
New 10” HD battery, waterbox, or tank strap -other OEM $14.95
New 11” battery, waterbox, or tank strap -other OEM $13.95
New 12” HD battery, waterbox, or tank strap $13.95
New 13" battery, waterbox strap or tank -Yamaha OEM $29. special buy $12.90
SuperJet battery strap $13.90
* Oem clean used, about 14 inches hook to hook unstretched
Shorter battery strap $13.90
* Oem clean used, about 12 inches hook to hook unstretched
SuperJet waterbox strap $13.90
Shorter waterbox strap $13.90
Tank strap $18.90
* Oem yami clean used, approximately 17" unstretched
Good for kart tanks and PFP style pipes.
New OEM Super Jet shorter gas tank strap 39.99 sale 33.89
* Approx 17" hook to hook-battery box side
New OEM Super Jet longer gas tank strap 39.99 sale 33.89
* Approx 24" hook to hook-hull floor to floor mount length
Blaster battery strap with pull tab $19.80
Shorty strap (6-6.5") $14.90
* Oem clean used, about 6.5" inches hook to hook unstretched
New 5.5" OEM strap 12.99
* 5.5" hook to hook, stretches to 7-8", ends are galvanized
Shortest strap 5.5" $12.95
(these have shorter metal ends, and will not work with std strap hooks without modding the hooks)
Strap Hull Hooks
New OEM stainless hull strap hook $11.99 sale 10.49
(The two on left side in photo)
Used OEM stainless hull strap hook $5.25
OEM captured strap mount -clean, used 7.95
(The two on right side in photo)
New OEM waterbox stainless hull hook with rubber bumper $41.99 sale 38.89
UFO Hull Mounts
JM UFO Std. 6mm SS hull mount $4.90/ea or 24.90/6 pack
(base plate 38mm diameter across and includes stainless allen shorty bolt for strap hook mounting)
JM UFO Junior 6mm SS hull mount $4.90ea or 19.90/6 pack
(base plate 23mm diameter across and includes stainless allen shorty bolt for strap hook mounting)
Perfect for gas tank, battery, waterbox, or pipe strap hook mounting to hull. Also can be used for mounting TL plates and eboxes. Epoxy directly to hull. Marine grade 316 stainless steel construction.
JM UFO Daddy SS hull mount 6./ea or 25./6 pack
(Uses all 8mm oem bolts like motor mount, midshaft, RN rideplate size)
http://www.x-h2o.com/index.php?threads/ufo-hull-mounts-just-landed.158921/#post-1709400
Epoxy for UFO mounting to hull
West G/flex thickened epoxy kit $40. sale 38.49
8oz mixed
* Thickened and Toughened epoxy to absorb stresses of expansion, contraction, shock, and vibration. Excellent adhesion. Great for dissimiliar materials. Shipped in US only
West G/flex thickened epoxy mini kit $14.99
1oz mixed
