SXR Rrp handle pole?
Dega
Mike
Toronto, Ontario
Hey guys iv only been riding for a year now and right now I'm about to install footholds wetpipe and a waterbox, so I was wondering is the handle pole with it? I'm on a lake and only really have boar wake to go after, also I was checking on rrps site and they are selling for 799 and I checked on bloison and they have the same but will all these extra parts you need for the sxr so am I missing something?
Dega
Mike
Toronto, Ontario
Just seeing if it worth the cost or keep the stock pole, but I'm just wondering is the pole from rrp for 799 the hole thing can it be put on stock or do you need all these exra parts blosion is saying you need?
The stock pole on the SXR is terrible and it WILL break. I'd wait till it breaks and then upgrade it, but if you got the cash now...go ahead and get it.
That's the same pole that Kawasaki used on the 750's. I still can't believe that they made the SXR and just used the same piece of crap pole on it.
Sanoman
AbouttoKrash
NE Tenn
Keep the money for other stuff.Yea,there is other pieces you have to buy to go along with the pole.What else has been done to the ski?
Sanoman
AbouttoKrash
NE Tenn
Hey,if you have your heart set on a pole,go for it! l'm just saying you could take $1400 and spend it doing other things,getting more "bang" for your buck.
Dega
Mike
Toronto, Ontario
Ok sounds good so then what would you guys recommend? So far all I got is wet pipe footholds water box , only otters I can think of right now would be afterburner and intake.
djkorn1
kidkornfilms
Cleveland Ohio
No afterburner!
No waterbox!
Get a flywheel.
& a Bilgepump.
Block off the front hole in your hood...open up a 2nd one in the back.
RRP poles are expensive, heavy, but bulletproof. Yes, you need a ton of other parts to run it. I would go with X metal or a stock SJ pole. (much cheaper and lighter) SXRs are heavy as it is.
