- NYC/Long Island
Thanks for the pics. Looks great, I just ordered one im having them paint it blue for me. I think in the check out process I had stared at confirm for like.. 15 minutes.
Ocean temp is 44. IDK about the bay though. Probably colder
I would suggest getting rid of that stock water separator going to your tank vent and cut the hose a couple inches above the tank vent. You'll be happy when you don't have water in your gas down the road.
Also the T to your flow control valve is reversed. the T side should go to the pisser and the straight should go to the flow control. Makes it easier to adjust the flow control valve IMO. It doesn't respond well to adjustment unless it has some pressure/volume going to it. Then it fine tunes much better.
Do you have dual cooling?
It's come a long way from "How you doin". Really nice job Kyle.
Looks nice, I have two 96/97 RN's that have stock graphics..... this makes me want to pull them off....
You should lighten the flywheel, or did you do that already?
