Riva 7 Port Cylinder?
Hi all,
I have an old cast r&d cylinder +8mm PV small bore (I was running 83mm pistons, sleeves are 87.7mm external) but unfortunally a wrist pin bearing broke and killed 1 sleeve.
I'm thinking to change the 2 sleeves but seems to be difficult to find small bore sleeves, next option is upgrading to sleeves for 85mm and more , someone has done this operation ? Does it change timing ?
Stockton
Hi all,
Mine was the same set up small bore without PV, Thrust Innovations installed bigger sleeves now bore is 85mm so you might ask them too
Stockton
Picture 634.jpg i dont know the size anymore, they are custom cut though, compression was set at 215 psi. they are blowing 200 now here at sea level
Mine was @190psi and runs perfect for me, but it was before the drama.
I don't remember dome size too but not very important because I need to change with bigger pistons, I just remember squish was 1.2mm
