- Newport News, Virginia
So I couldn't find anything when I searched, as far as how to go about this. Read places that they were easy to pull out and they were only 1/8" thick... Well that's not the case.
I figured it was easy enough but being this is my bran new Superjet, I was hesitant. So I thought I'd take pictures and that way the next noob knows what they are doing.
I do need to figure out which T handle screws will work with the hole the screws go into being so deep.
But here you go.
Center punched (optional) I guess
Drill a small pilot hole.
Using a regular pointed screw, not a self tapping.. Self tapping screws will begin to cut the adjustment screw.
I had my carbs in a vise which made the next part easier.. I used bent tip needle nose pliers to leverage them out.
Now I wish I can say they all went that easy.. But I had one that the screw broke and I had to drill it a few more times. Also they are about 1/4" thick.. Keep that in mind when drilling.. I was expecting 1/8" and got nervous as it kept pushing through. Don't wanna go too deep or else you may mess the screws up and have a hard time removing them.
But here you go.
