I am in the middle of defoaming and have seen quite a few people use the pink construction foam which I think is the route I will be going. A good amount of people have also included a drain plug in the back in case water does get in again. This makes sense to me but then they use the 2 part expanding foam on top to level things off before they glass as well as hold things together. Wouldn't this mean if water does get in again that the foam would be waterlogged again, then making the drain pointless?
Even if the water passes by the 2 part wouldn't it still become waterlogged? Any pictures of your setup or build would be much appreciated.
