rag's sn freestyle/freeride build
hhh
got it painted tonight. this finish will be fine for a little while. i would like the powder coating, but i dont think i have time to get it done right now.
accbr
addicted
Lexington, KY
Looks good. Even looks powder coated in the picture. I used high temp black barbecue paint in that hull if you ever need to touch it up.
hhh
thanks man if i have any down time this summer i may still send the pipe to get it coated. im just about to have it water ready so i hate to start sending stuff out now, i just want to ride.
hhh
well got a new wear ring ordered from oxnard and new gaskets from the dealer. should have everything this week and together. i hope i dont find any more surprises and can test everything later this week or next weekend.
hhh
ok here is what I got completed tonight, engine is in and aligned, pipe is in, everything plumed and ready. i will get my new wear ring this week and then the pump will be in. i gotta say im feeling a little relief now, it looks good and im really pumped about it. its been a few months of some tough work and i am real happy to see it all starting to come together.
A very BIG thanks to everyone on the "X" that has sold me parts or gave me advice i sincerely appreciate all of it, this build would not have been possible without you!! This is almost 100% built from parts bought off of "X" members!!
so Will and Chic, what do you think?
BROSS
The future right here
Lake Norman, NC
Super clean, I like the Blue head, a buddy of mine has the same one in polished. Those carbs look good too, LOL. Let us know how it runs, should rip.
hhh
after looking over my cooling lines again i noticed im not the same as many others here.
and btw im only running single cooling until summer, water is in the 40's here.
this is what i have now, 1 in from pump "T" two lines going to manifold-off of the head "T" to bottom of pipe-top of pipe to stinger "T" to pisser.
is this ok or should i run the head to top of pipe, and bottom of pipe to stinger?
or is either fine?
thanks
matt
hhh
thanks man, i want to ask you about this jetting
130
62.5
2.0 n/s
pop off=???
i can check pop off later this week. im just concerned its lean. FP recommends a 135 dont they?
im just double checking, didnt you run these carbs on a similar set-up?
accbr
addicted
Lexington, KY
It's not all mail order. That hull was hand delivered. :drive:
The only difference in your cooling lines than what I run is the T into the head. Most setups for single cooling just have one line coming off the head to the bottom of the pipe. That'll work fine though. You're still accomplishing the same thing. Also, I run a flow control valve on the T to the stinger to keep the water box a little drier.
hhh
the short block too!!
i do plan on running the flow valve im just in need of more funds before i drop 50 on that. im taking to many trips and the build is suffering lol
at least om going places to ride :arms:
hhh
well i got a few pics nothing new or exciting in them, but my ski is alive for the first time!!!! turns out im a dumba$$ and had a solenoid wire backwards
:twak:
so here are a few i took right after i took it off the hose :Banane09:
this thing sounds great and im ready as soon as my pump gets here:beerchug:
gorilla
There's Always A Light At The End Of The Tunnel !!
Lost Wages NV
you know with all the chit that's happened over on pwctoday between me + you, i am going to send that sn pump to you !!!!
after looking at all the pain you have gone through with that ski, i feel kinda sad that we did not hook up in a better way.
over a good long wet ride or a couple of beer's at the lake !!!
i'm sorry for the mistake i made on the driveshaft lenght issue.
i'm not perfect !!!
gorilla
Kennay
Squarenose for the _____
Myrtle Beach, SC
i'm not perfect !!!
gorilla
:smoker:
