- central florida
Op= original poster
Yes, to all. Since you seem to be new to this, consider taking a close up picture of the drive shaft splines that stick out through the bulkhead-before you wipe it off- and post it here.Sorry I’m not sure what you mean when you say “op”. So sounds like what I need to do is take the entire assembaly with housing off, replace the o rings and coupler with an updated one, grease the splines, then put it back in?
