pulled hull drains today....
grezzmky
Suckin paint fumes
Saint Louis MO
I am glad I used the polystyrene and put drains in my hull! I pulled the drains today and after only riding one season about 2 cups of water came out of the left side and about a 1/4 cup from the exhaust side. I 5200ed EVERYTHING and it still happened. I do have to say that it was samped twice last year and sat outside for awhile and had a couple inches of water in the bilge for a couple days (still dont really know hay that happened).
Proformance1
Liquid Insanity
New York Crew
Mine was the same, really glad i installed the drains and the styrofoam. Now I'm thinking of installing the versa plugs, if I see much water intrusion.
I must have some massive cracks in the tray. The bottom deck is tight, so are the cooling lines and inserts.
sjetrider
It seems near impossible to completely seal that area. But 2 & 1/4 cups of water is NOTHING in a season. there is generally more than that in the bildge area at most times when riding. That ia a battle not worth fighting IMO.
I used Plexus on everey through line, exhaust and rideplate / pump bolts when I assembled my REV and still had water come out one of the ride plate bolts the first time I took the plate off. Not sure what the answer is so no sense it battling it. I know the ski weight the same 2 mos. after assembly as it did when assembled whithin a couple pounds so it really didnt matter. at least I know it will float for a minute.
Proformance1
Liquid Insanity
New York Crew
You bring up a good point about the bolts. I think some Loctite 572 may be in order for my ride plate, pump, and intake grate bolts. That should hep seal them right up.
