Engine problems!! Any Suggestions!?!?!?
I bought this ski last year and since I got it, it never ran right. The guy told me he had just put a new carb on it and all I needed to do was just adjust it, yea if only it was that easy... I got screwed:buttkick:. So I took it out several times tried all the adjustments, it seemed to improve alittle not much. It won't take off fast, and the low end is weak along with the top end. It only tops out at 30mph. On the trailer it sounds awesome, but in the water under a load it's just a dog. I tried many things to fix it with no good results. I switched the carb compleltly, didn't help. I test the compression... everything is perfect there. I put a new intake grate other one was cracked. I tried a new impeller also. Everything seems fine. The only thing left I can think of is that the motor was ported for a pipe or something along those lines.
If you have any ideas on what else I can check on it, or why it would be running the way it does just let me know please!!!
Thanks.
Thanks.
