Pro tec trim system, help
IceRocket1286
Metro Detroit
Im using a wave raider/pro tec combo for my freestyle trim. I cant figure out how these stupid brackets mount on my pump so that the cable holder mounts in place.
I need some pictures of a pro tec trim system on a superjet if anyone has ANY, or any help.
F
Freestyleriverrat
Guest
I run this system with a blaster nozzel and it works great. You will need to bend the bracket a little to keep the nozzel from hitting it and limiting your trim up function. I mounted the cable to the reduction nozzel directly behing the cable mount. I am not only using the blaster reduction nozzel b/c that is what came with the system :) but b/c it is metal as opposed to plastic and will retaim more strength when borred and mounting trim stuff to it.
F
Freestyleriverrat
Guest
kingnothing3 said:
do you have to have the spring on there? i thought the jet would naturally straighten the nozzle out?
It will but I just did the reverse of what this system was designed to do which is trim down. I have not tried it w/o the spring and am not sure I would want to. I like how it keeps the nozzel centered, however depending on the spring you use it may take a little more pull to trim the nozzel b/c you are not only working against the force of the water comming out of the nozzel but you working against the force of the spring itself. I just played around with different spring tensions and it all works out well. It gives nice throw also
F
Freestyleriverrat
Guest
It is a blaster reduction nozzel........everything else is for a SJ. It is a pro-tec system minus the pro-tec reduction nozzel.
surfgy45
just add gas...
San Diego, CA
oh, its not that maxflow nozzle set up? the reduction nozzle has the 4 spots for bolts build in (top and sides)
this is what im using and thought maybe i could use a raider trim ring? and thought thats what you guys were using
