schicks
Karma Enforcer
- West Michigan
I am replacing the pump stator on my 2001 sj with the solas mag setup. I have it pulled apart, just need a little guidance on pulling the shaft out. Can I leave the prop on the shaft when I press the shaft out pressing from the exit direction? The manual seems to show pushing the shaft out from the prop side and letting the bearing come out with the shaft, then you press the bearing off the shaft.
Is it possible to press the shaft out from the pump exit side while leaving the bearings inside the pump stator and the prop on the shaft?
