I don't believe it totally matters what psi they are, as long as they are similar. Both of mine were within 1-2 psi of each other, so I think you're good. If you aren't having any problems related to pop off, then you should be done.
If you want, you could check to see if there is a leak while it's apart.
-To do that just submerge the needle and seat with something like WD40 and slowly increase the psi up to pop off.
-If you see tiny bubbles coming up just before you reach pop off, then you have a leak.
-This can be easier to do with a friend, so one person can watch the pressure, while the other closely watches for tiny bubbles.
I hope that helps,
James Ross
